belt issue
GHETTOBLASTER4LIFE
Hey ... im sure you guys have been ask this about a zillion times.... what belt size you get for a boombox ?I seen a few belt lots on ebay but im not sure which auction to go for.
Here the radio..its a rexcel....takes 2 belts on each drive,only need 2 though...one side doesnt work at all.
Thanks for the ANY HELP.
Oyea the belts that were in it was about the same thickness of regular rubber bands...not the big flat ones.
Im sure a inside pic would be alot more usefull....ill try to do that when i get time.
You need to measure belts to get right size. Measure length by using a couple pens, then multiply by 2. Then subtract 5-10% for stretch. Then measure width. I usually buy the size then one size up and one size down just incase..
Bad Boy Bill
GHETTOBLASTER4LIFE
Bad Boy Bill
Cool...thanks bill.
