battery compartment failure
shakespeare
My lasonic 931 (first gen) works great plugged in, but once I insert all the batteries, it doesn't power on. The battery compartment looks very clean though. Any tips? anyone else with this problem?
is there an ac/dc switch on the back of the box? if so have have to set it to dc to get it to work on batteries.
devol-toni said:
Try with a set of brand new batteries. :blush:
I know that might sound obvious, but it definitely makes a difference in some boxes. My Clairtone had some old Energizer batteries in it and still worked fine. I took them out and placed them in an M70 and I got nothing. Bought new batteries for the M70 and it cranks now. :yes:
MasterBlaster84
:agree: this is the most common reason one power source doesn't work on the 931's. :yes:
Even if you switched it to DC it's still possible the switch isn't working properly, give it a little De-Oxit treatment first before digging in to it.
shakespeare
This is exactly what happened. I just bought some brand new batteries and it works perfect. The batteries i had used before were only a week old and they worked fine on my other boxes. Wow, this lasonic must really be powerful, ehh. Thanks a lot guys!!!! respect!!!
Super yay!!
Oh, and...
Welcome aboard!! :-)
Soundwave
sometimes rolling the batteries in the compartment has helped at times...or moving them around....could be the contacts
stynger007
Hate to admit it, but I am guilty of such a simple switch setting- :-O ;-)
