Basshead, parts
T-STER
Sorry all, no idea how to send pics by pm so posting here.
M70 handle - needs a minor cleam, all fixtures are on it inc little black pieces taped to handle. Straight.
RC550 mid grill - Good paint, minor indents, think its been strightened out at some point but looks good.
RC550 tuner window - pretty much mint, very clear and looks great.
JustCruisin
If I remember correctly, you use the black piece and brass colored metal piece of the handle brackets to use on the 550. Also, the M70 handle is about an inch too long for the 550, but using a fine hacksaw blade to trim it and to drill a new setscrew hole works perfect! It's what I did for my Prince tribute 550. :yes:
BassHead
Thanks Tre. Tuner window looks great. How difficult is it to remove the tuner window? Does it just involve using a hairdryer to melt the adhesive holding the tuner trim in place? The speaker mesh does like nice as well!
I'm a little hesitant on going the hacksaw route with the handle. I've been happy with the Blu_fuz strap, that I've almost forgot about needing a handle.
