audio sonic tbs 1100
systemaddict
Not been on for a while, lost a bit of interest and been putting more time into graffiti art. Anyway I got this bad boy today, great condition and fully working. This is probably the nicest looker I have ever had, good sound too and very loud. However I have a small problem with the aux input. My aux lead is loose when connected through the feature on the front of the box, this is kinda baffling as the lead don't fit so I get no sound. It reads aux on the selector switch but the actual port reads aux mic mixing on the left port, and and aux mic on the right one. I'm thinking I may need stereo jack adapters, and may have to use the mic mix feature for aux input like on the 9191. But do I need to use one port or both? The 9191 only has the 1 mic mix port but this bad boy has 2. Any help would be greatly appreciated. Here's a couple of pics to give you an idea of what I mean.20160803_152726.jpg20160803_153755.jpg20160803_152726.jpg
There are no other inputs?
Those look like 3.5mm inputs, instead of the usual RCA inputs. You will need to buy a Y cable with one 3.5 on one end and two 3.5 on the other end.
systemaddict
static2000g said:
this is an awesome looking box!! Great find. My first seeing this box
Thanks static :-)
No there are no other inputs Reli. What is the cable you speak of? never heard of one. Do you have a pic you can post up? would be much appreciated.
systemaddict
Reli said:
If you take your phone's earbud cable and try to stick it in one of those, does it fit? If so, that's a 3.5mm, and you will need a cable like this:
http://www.ebay.com/itm/3ft-Stereo-3-5mm-Male-to-Dual-3-5mm-Stereo-Male-Y-Splitter-Audio-Cable-AV-Y093-/390797824700?hash=item5afd5d92bc:g:A54AAOSwezVWzncR
Yeah it seems to fit Reli but not properly? seems like the connector ends are the wrong shape. They are smooth and have no grooves like the one in your pic. I think I can get some adapters like the ones in your pic, from my local electronics. Thanks for your help mate much appreciated :yes:
systemaddict
Mystic Traveller said:
Nice stereo - congrats! :yes:
I am wondering what does "High Filter" switch do?
Not sure what the high filter switch does Alex? When switched on it kind of sounds like dolby nr.
SLO
Took the words right outta my mouth :jawdrop: That thing is gorgeous!! I've never heard of or seen this box, but man I'm gonna be on the lookout now, congrats bro.
It just reduces the Treble. It's a pointless feature, to be honest. Most boxes don't have enough treble to begin with.
systemaddict said:
Sorted the aux issue now too, sounds purdy :thumbsup:
What kind of cable did you get?
systemaddict
I didn't need a cable Reli, I got these adapters from my local electronics. They fit on the end of the aux cable and now fit nicely. If you look at them you can see they are different to the aux connecters. Anyway at £1.20 each I say real bargain. Now I have proper aux☺20160804_203056.jpg20160804_091748.jpg
SLO
20160804_091748.
Sweet!
MyOhMy
Nice looking BB, is as good all round as it looks? Because it looks so nice and 'un-brutish' it looks light to carry - but is it?
