I unscrewed a telescoping antenna from the pivot / swivel base to take apart a box. Now I tried to put it together and the antenna won't stand up-right. If I don't keep it propped up, it will drop to the ground. The friction needed to keep the antenna raised..on its own will...is just not there!
I'm almost certain that there wasn't a washer, but who knows since this screw is so dang small. Regardless it's a pretty snug fit, and when I connect up the antenna to the swivel base, I don't think there is even enough width to install a washer.
What am I doing wrong here? I've done a bunch of internet sleuthing, and can't find this topic anywhere, so I must be the only idiot
Thanks in advance!
Thanks in advance!
