Here is a radio that I brought home from Japan. It's a little power house Aiwa TPR-820.
Sadly, when this radio showed up, it wasn't quite how it was described in the online auction. It had one antenna with a broken tip and no battery cover
These Aiwa's, like the Toshiba's use a white tipped antenna. Thankfully our good brother StrÄnj-BÅÅmbÅks mailed me a replacement all the way from Venezuela
Today I started work on building a new battery cover door.
Below is how I did it...
It just so happens that I had a sheet of aluminum plate that was just the right thickness to make the cover (pure luck)
I trimmed out a piece to fit where the old door was...
I then bent it with a small table top sheet metal bender...
Then trimmed out the back side where the tabs would go that hold the bottom in place...
The fit and finish was coming along pretty good
I realized that I was going to have to cut away the bottom tabs and fabricate new tabs from stainless steel sheet metal and pop rivet them on...
Here I'm fabricating the spring clips that hold the door closed. This took a few attempts, probably made 3 versions before I came up with these. I used a pop rivet as the ridge that actually hold the door in place.
Here is the finished door with the spring clips trimmed down...
I will be painting the battery cover when I paint the whole radio. But considering I had no door and now I have one, makes this radio usable once again. It may not be factory, but it's better than duct tape
I even got my new antenna on!
