Fatdog said:
There are 38 steps in aligning the tuner on an M90. That's definitely not a "1-screw" kind of job.
EGGZACTLY.
I did not know a nice way of saying it so I have been mostly avoiding posting here. But as far as I'm concerned, let's just say there is the right way, and the NO-WAY. If I don't have a service manual with adjustment procedures, sequences and specifications, I don't touch. Even WITH the service manual and schematic, sucess is not nearly at the ratio that I'd like to see which is why I basically don't like to take those jobs. AND yes, I do have oscilloscopes, signal generator, stereo modulator, marker injector, etc.
If I knew that a boombox tuner was messed with before, I WOULD AVOID THAT BOOMBOX LIKE THE PLAGUE. The tuner is the most difficult circuitry to work on, on any receiver. Even many technicians that have no problem working on audio issues will have their tuner specialist do the tuner. It's a very difficult art/science to master.
Whoever suggested to play around with 4 screws to adjust the tuner is way off base and flat out WRONG. Nothing can be further from the truth. Even with the proper equipment (already discussed), it is very difficult. Without the equipment and tuning blind -- that's just a big no no. Can you make it better? Maybe. Can you make it worse? Absolutely. Can you screw it up totally? Very possibly. There can be 4 adjustments -- there could be 14 adjustments. How many, and whether you will be adjusting the varicap, the variable pot, the RF tuning coil, transformer, inductor coil, etc -- all depends on the tuner and layout. The fact that you mentioned 4 screws without even saying what type of componentry you are adjusting just tells me you don't know the difference betwen a L101 or a T101 or a CT101, or a VR101.
The answer therefore is NO, there is no secret -- just years of education, training and tons of experience. Tuner adjustment is DEFINITELY NOT a novice project. Any adjustment that seemingly made things better at one location of the tuner dial probably messed something up at another area or another band. My suggestion? If you can live with it, by all means leave it alone. If you can't live with it and it's a cheapie that you can toss/replace, then go ahead and play with it. You already decided that you can't live with it. If it's a big $$ irreplaceable job -- do it right and farm it out. Just My 2 cents.
