A new design for Panasonic RX 5150 front Face
The sound quality of Panasonic RX 5150 surprise me..... but with the current design I want to hide the front face and listen to it.
I have one that I bought so cheap that sound the best! That box exterior is all scratched up. I fixed the interior and sounds so good!
I do have 2 like new ones also, but still that beaten up box sound is just amazing!
I wonder if someone can come with a new face cover ..... modification for RX5150.
Just a thought!
ROyce that would be a great box to paint a different color and maybe put some real grills and some different Tweeter trims.
In my opinion, the only thing the RX-5150 really needs is real speaker grilles for both the woofers and tweeters. :yes:
Superduper said:
Are we talking 5350 or 5150? I'm sure confused.
Norm cannot get confused!
My bad! I put 5350 in the content by mistake!
5150 and not 5350.
That is correct Bobby! It is not easy to cut it out from the box. It can be done!
Floyd, That would work. Grills are the bad part. We have to cut it and grind that cut area.
Royce the easiest way to do it is to break that Grill off in pieces because it just snaps off clean around the edges.
