I have used JB many times...in fact they have a great 2 part mix especially for exhaust manifolds. Works great.JVC Floyd said:awesome job man, you know what works great for filling holes like that is the jb weld type putty that you knead and press into place .i use that stuff a lot and it works great . the trick to it is to shave off the excess material before it hardens then you only have finish sanding to do once it hardens .
If only my bad back could handle leaning over the fender of a car all day.devol-toni said:This is the art of repairing..
I am impatient to see the final result..
Chris, I'm sure you could get a job at any time as a master in any auto body repair shop..![]()
Oh yeah....it will be much nicer before we get to painting...Northerner said:Excellent stuff!...I'm sure you probably know but just be aware that any imperfection on like the edges or corners that look acceptable now may not once painted as it shows up much more once painted. I'd be putting a little filler where the little imperfections are on the edges and resanding![]()
It's coming along. I probably have 15 hours in it already.blu_fuz said:Holy shiat that's awesome!
k2j said:No doubt about it, you gotz skillz. Very good job so far. I was kinda hoping for the robocop/blaster look but this will be minty!!
