You ever drill a hole with a needle?
10,669
168
40
WI
So far, I was only able to do the work and make sure the feelers line up on the pot board correctly. I do believe it is going to be 100% functional.
Matter of fact, this is a COMMON problem for JVC M90 potentiometers. The melted plastic buttons that hold the feelers on eventually break off. Could be an age, use, or abuse issue.
We have been discussing behind the scenes that these M90 pots should be opened up now and reinforced with a small screw in the center hole of each feeler plate. Probably add a dab of epoxy to the existing plastic buttons and these should last a lifetime.
Some of us might already have a damaged pot and not know it.
Mine was acting strange.
From 0 to about 3/8 volume mine sounded OK but a little flat like if the loudness was off.
Then from 3/8 to about 1/2 volume there was scratchy left speaker only and right speaker didn't work at all unless you fiddled with the knob shaft.
Then from 1/2 volume and up it was nice and clear out both channels and as if the loudness was working again.
The knob rotation also didn't have the soft tension on it like my other M90 volume knob had.
14,130
108
Naples, Italy
So basically it was worn out in the "Typical Use" section of the knob position. Makes sense.
This is important information for ALL M90 owners! (i'm not one :sad: )
JustCruisin
3,100
17
Midwest, USA
I'm reaching far into my memory banks on this...But, wasnt the word on the streets that M90 shares its volume pots with Panasonic 5050..? :hmmm:
10,669
168
40
WI
Close
You lose balance control, loudness, and the D shaft is rotated different so the M90 knob will never point to the correct volume setting. But, a panny 5050 pot is better than nothing!
10,669
168
40
WI
I guess I should have posted this in the JVC M90 section.
I dabbed a little white lithium grease on to the base of the shaft where it enters the metal casing. That is to restore the soft turn motion that it originally felt like. Got it closed back up. The motion feels almost as good as my othe M90.
Hopefully it all works after the box is back together.
10,669
168
40
WI
The repair worked PERFECT. 100% restored sound and fixed to last. Very happy right now :w00t: :clap: :rock: :thumbsup:
5,760
274
2,508
344
That's not a bad idea. Maybe I can cover the spots with conductive paint. I'll never make the same recipe to recoat those spots to make them exactly as they used to be, but most of it is at the end of the scale so it may not be noticeable.
Newclairtone7980
35
ontario
hi I'm new but what I was trying to say that the jb glue would work the best I'm going to do that to my pot your right the screw would do damage to it
