Which Kaboom is the best for BASS/POWER?
6,321
453
At least the DB200 doesn't have those gummy endcaps that need to be cleaned with alcohol
superlew
1,087
Woburn, MA
That's probably the biggest issue with picking up a well-used B90. I spent two afternoons stripping the end caps and knobs, then another afternoon prepping and painting them in flat black. The end result was great, but it is a lot of work.
Other than that, I find the B90 to be very rock-solid and reliable if it hasn't been abused.
Shakes the walls nicely, too. :yes:
Eddy
598
19
Get a DP 200 if you can. I found one on a local second hand website for only 50 euros. Fully functionnal and with the remote.
It's the 3 way sound control that makes these sound better than another kaboom version. I like the CD pitch contol too
jimmyjimmy19702010
3,578
26
Sunny Brisbane, Australia
I hear an early version Kaboom playing at a warehouse i visit regularly. It sounds very bassy/boomy in that environment. The drums sound muffled and loose, not a tight, controlled type of beat.
It would definitely benefit from stronger highs and a more controlled bass line.
