UK/EU Replacement Belt sizes from DeckTech
mnemonix
4
4
London
If you are looking for replacement belts in the UK or EU you may have noticed that the belt codes given in the manufacturer threads above refer to belts that are only available in the States at astronomic shipping costs to Europe.
Deck Tech belts are available direct in the UK on ebay, though they are sold by Diameter in mm NOT Circumference in inches.
To find the correct belt, convert the inside diameters given in the US belt codes to mm and look it up in the table images provided at the links below to order the correct size.
For example a FRW-10.2 belt for a JVC RC-656 = 259mm circumference = 82mm diameter (x 3mm width)
DeckTech 3mm Flat Belts
DeckTech 5mm Flat Belts
DeckTech 1.0mm Square Belts
DeckTech 1.2mm Square Belts
DeckTech 1.5mm Square Belts
