A better response would have been. Thanks for the Helpful instructions, I have removed the belts as you instructed and now confirm the motor is not turning when powered up with no belts. However I can spin the motor by hand so it not seized.FWSnake said:It ceases to rotate, meaning it is being blocked or obstructed by something.You are right, I overlooked that the motor is humming.
So voltage and mircoswitches are probably OK.
Is the motor rotating or is it somehow blocked?
After removing 2 of the belts you can find out if the motor is blocked or the gears it is driving-
If this is what you have done you may be able to service the motor or replace with a similar one.
