Hello my fellow boombox enthusiasts! As you can see by the thread title, I have a Aiwa TPR-990 that has no audio coming out of the left speaker on radio mode. I cannot attest to whether the left speaker will produce sound on any other mode because the tape teck needed new belts. Here's what I have done so far:
Recapped entire boombox, yes all 118 of them (I know... I'm crazy)
Sprayed the heck out of the mode switch and slid it back and forth about 50-75 times (till I lost circulation in my fingertips basically)
New belts all around.
Now here's what's going on:
1. The tape decks' soft touch buttons are jammed, frozen, will not move at all.
I've taken this thing apart and reassembled it about 10 times and no matter how I adjust the gears in the MD-1 mechanism it's always met with the same result in the end.
2. No audio from left speaker in radio mode.
When I have it in "tape" mode and spin the motor drive mechanism by hand, the "play" actuates and the "play" symbol light comes on but the cassette gets tangled in the pinch roller on the bottom right of the cassette assembly. All the while I can hear light "crackling" sounds emitting from the left and right speaker whether or not there's a cassette in the deck (the "balance" is centered during this time). I've tried to lubricate and clean the "balance" potentiometer but it is a PAIN to get to (you have to strip the inside clean of nearly ALL the parts.)
Any help will be very much appreciated as I am about an inch away from throwing it against the wall. Thanks!
