I'll post this here on the off chance that someone is struggling like i did to find proper case screws.
I found some 50x3mm self-tappers that perfectly replace the ones in my Panasonic rx c60. They are silver and the threaded part is longer, but they do the job.
Here on ebay:
Or search for:
Screws Self Tap 3mm x 50mm Pitch 0.50mm Per 20
Here on ebay:
Screws Self Tap 3mm x 50mm Pitch 0.50mm Per 20 | eBay
Screws Self Tap 3mm x 50mm Pitch 0.50mm Per 20.
www.ebay.co.uk
Or search for:
