As described in this old post
Unfortunately no solution was provided.
The right channel works in mono and wide but is distorted in stereo mode only and on all functions.
Things done.
Pots cleaned.
Traced audio and tested voltages from power amp IC's back to the mono/stereo/wide switch.
Tested components, caps and resistors and checked in on the transistors around the mono/stereo/wide switch.
I noticed there is a higher than usual voltage at q115 (phase shifter) base and emitter but after desoldering the base and emitter legs, there was still 6.7v at base pad when it should be 2.7v. Shrug.
Tried switching q115 and q116 over to see if this little transistor amp was the issue but the problem stayed in the right channel. The issue seems likely to be a capacitor issue since on powering up, sound is present then very quickly quietens and distorts.
I make the assumption that since the volume adjusts perfectly in mono/wide modes that the volume pots are functioning accordingly.
Anyone any clue or resolved this issue before? I can't figure put what components are used in stereo mode but not in mono or wide.
Sharp GF-9191
I thought I would go ahead and post a thread here while I wait for a service manual in the hopes that someone else has encountered - and fixed - my problem before. I'm restoring a Sharp GF-303SG that is basically the Japanese domestic version of the Sharp GF-9191. Everything works on the...
boomboxery.com
Things done.
Pots cleaned.
