Sanyo tape motor question...
91
If the voltage matches and the direction of spin is the same, then yes it would. You would first check and see if the motors have the info of volts and direction on them. If not you will need to measure the voltage at the motors then see what direction cw (clockwise)or ccw (counterclockwise). When you are facing the motor and its running is how you tell. You can also buy new motors here :-D http://www.studiosoundelectronics.com/cassette.htm
