sanyo m7770k boom box power supply polarity?
1,287
287
Melb AU
AC or DC? AC should not matter DC will only work one way. There maybe an AC interlock in the orifice these can fail.
goodman
2,332
237
50
Bulgaria
if you look carefully from the side you will see the polarity: minus - ) plus
You need the following ac dc power supply: LINK
!!! very important - if you get the polarity wrong you will damage the radio !!!
Scott16
Marblehead MA
I just got a black Sanyo M7770K and I couldn't tell by looking whether it had a positive or negative center pin on the power connector
so I used a multimeter continuity tester and discovered the center pin is positive on my M7770K.
