OK lets slow down.
The more detailed picture shows that for number 4 we would be jumping to the same side of the board.
Without that black wire you put in place, is there continuity between those two points anyway? If so, remove the wire for now.
Don't forget, we are jumping wires across the crack to provide connectivity which is broken.
Personally, I would get the board straight and glued with something supporting it across both sides first (matchsticks) and leave glueing directly across the crack for now.
The reason I would glue it is so that we can jump this number 3 by simply replacing the capacitor for a new one (of the exact same value) and use the longer capacitor leg to go to the leg of resistor R345 like below.
We can then deal with the other leg of R345 separately to check it is connected.
Once we have everything in place and as it should be, we can worry about the disconnected wire.
