RX-DS45 Casette Player not working
Cynicelectronic
5
44
UK
I just got an RX-DS45 Radio Recorder cassette player not working. I
t has a good sound CD-Player working and has RCA AUX IN. I've connected a Bluetooth adaptor to AUX IN.
I want to convert to a rechargeable battery operation portable speaker.
1,059
788
113
55
Maryland usa
I would assume it probably needs new belts which means you'll have to disassemble the unit which would be a great time to do the battery mod.
Cynicelectronic
5
44
UK
Tha
Thanks for the quick response. I will be looking for a belt set then.
(Unfortunately, the cassette player has no mechanical buttons, just membrane switches.
Cynicelectronic
5
44
UK
I need a long screwdriver as well. I've ordered this one "Stanley Fat Max Screwdriver Phillips Ph1X250Mm".
I hope this reaches the screws.
Cynicelectronic
5
44
UK
Thanks for the quick response. I ordered a belt set from eBay and a long screwdriver as well. (Stanley Fat Max Screwdriver Phillips Ph1X250Mm)
Unfortunately, the cassette tape player has no mechanical keys, just membrane buttons.
Cynicelectronic
5
44
UK
Belt replacement done. Still not working. I've find the problem. The casette sensor was oxidated doesn't realize the tape in. I've sandpaper it. Now it's working!PXL_20220803_193525702.jpgPXL_20220803_175756840.jpgPXL_20220803_175810222.jpgPXL_20220803_175818161.jpgPXL_20220803_175821972.jpgPXL_20220803_175837021.jpgPXL_20220803_175839929.jpgPXL_20220803_175905875.jpgPXL_20220803_175910075.jpgPXL_20220803_175916361.jpgPXL_20220803_180204603.jpgPXL_20220803_180206364.jpgPXL_20220803_180209905.jpgPXL_20220803_181242357.jpgPXL_20220803_181245540.jpgPXL_20220803_181253097.jpgPXL_20220803_182618266.jpgPXL_20220803_183244602.jpgPXL_20220803_183250248.jpg
Reactions: lupogtiboy
