Replacement pin for spare tape drawer
2,514
346
I thought this might be useful for those with a missing drawer pin. You just grind off the old bracket and glue this on.
The pin sits halfway on the back wall, so my pin overhangs to keep this position. I added some bracing behind the pin when I drew the tray, which really helps here. There was just enough room without hitting the chassis.
