I've rebuilt so many of these engines I recite 18436572 in my sleep You Chevy guys will know exact what this is
Yeah, and painted the driveway!Superduper said:
Ok, and the problem is? Lol.blu_fuz said:Yeah, and painted the driveway!
What you can't see is that 2 dogs reside in that garage, and they are shedding like a group of abominable snowmen in the desert. It gets into every nook and cranny and crevice. Every time I pick up a tool, if it is at all greasy, it is completely covered in fur. And the more I wipe, the more fur gets on there because it's on the roll of paper towels too. Also, at this time of the year, these pesky wasp looking things keep flying into the garage and building these sandy/mud igloos everywhere and anywhere there is...... a hole crack or crevice. Therefore, I make it a point to keep as many holes and ports plugged if at all possible. The filter was like $3 at Walmart and easier than applying masking tape to the oil filter adapter when it came time to paint the engine. A few simple twists and it's all sealed up! At least those holes. You can even see the orange overspray on the filter, lol. The rest of the time, the engine has 3 layers of plastic bags covering it. So yeah, I bought the very cheapest oil filter I could find for that purpose. As soon as the engine is started up and run through the break-in routine, which takes 20 minutes at 2000-3000 rpm, everything will be drained and the filter replaced. Putting in a better finer filter will only ensure it plugs up faster (not good when breaking in). So yeah, there's method to the madness.JVC Floyd said:I see the mock-up oil filter totally logical. excuse my ignorance lol.
You'd really have to use a clearcoat over the color and as Super mentions a two part (or 3 part, clear-reducer-hardener) would be better. Single stage paints such as what you likely used, will always have something come off when exposed to solvents (gasoline included). Just the way it is.robgmn said:Before I got through your post, i was thinking "those fins would look good stripped and mirror-polished", then I read "2000 grit" and knew what the following picture would be (I use 2K to get mirror edges on knife blades sometimes).
Looks good!
A question if I may on painting for chemical resistance: My son and I restored my 1969 Rupp minibike last year as a father-son project. No spare $$ to re-chrome the gas tank, so we rattle-can sprayed it with a bright silver, which was left to cure for several months.
It melted with the first minor spill of gas (not unexpected).
Any suggestions for doing something that will withstand gas long enough to grab a rag and wipe it off if some spills during fueling?
There are a lot of Google hits about paints that will NOT resist gas, but I'm not having much luck about those that CAN resist it.
