Hi guys, I recently acquired a Philips D8734 in very good conditions that went for not a high price because it was sold as untested. It actually turns on, radio works and the sound is nice when loudness is engaged but unfortunately going further with testing I found a lot of problems. I almost immediately noticed that when the mono-stereo-spatial knob is used, if you want to listen in the stereo position the right channel is very low volume (in the other positions the level is Ok-ish), tried deoxidizing the pot but nothing changed. I then selected aux source position and a loud hiss is coming out off the speakers (I even tried with headphones but it's the same), incredibly the same happens even when moving to phono (only the hiss is a different frequency), already tried deoxidizing the source selector switch but to no avail. Another problem is with the deck B, in which the play-rec head was floating around since both plastic posts where it's secured with screws are broken (this will be a nightmare repair because the broken pieces are very small and there seem to be plastic fragments missing or impossible to glue back because you cannot even try to figure out how to handle them); obviously both cassette decks suffer from the usual "cheese gears" plague that affects Philips (but even Grundig or others) decks of that era but it's possible to buy very well made replacements from eBay, even if they are not cheap.
I really hope that some of you can help me trying to figure out the strange problem with phono and aux input, never seen something similar before, even the pot that changes the sound stepless from mono to spatial spereo (Philips name for wide stereo) is driving me crazy actually...
Many thanks in advance.
