PHILIPS D8444 BELTS NEEDED/PART NUMBERS ETC
STEVED8444
Hi,everyone.
I thought i would buy what i could not afford in 1985 as a break dance wanna be fifteen yr old lol.
I bought one a year ago but the tape counter never worked but played tapes until a few weeks ago.
Where can i get a replacement drive belt and missing belt for tape counter.
I have my d8444 in bits at the moment and i can see the drive belt is snapped so i could replace that one,but the tape counter one is missing .
Does the tape counter run off the same motor and then to the counter pulley.
Any pics,advice gratefully received.
Thanks steve
STEVED8444
Hi,thanks for the help.
I believe i need a sbo 7.2 for tape counter and sbs 9.5 for main tape drive.
I cannot find sbo 7.2 on there website?
Thanks steve
91
STEVED8444 said:
Hi,everyone.
Thanks steve
Honestly another issue with these units is the gear that breaks and causes deck not to work as well so you may want to check into that. ;-)
