PC-5 Deck Intermittent Drag
429CV23
17
4
Recently picked up a PC-5 system. Replaced the 3 belts, lubed the capstan and capstan motor shafts. Still has an intermittent drag when playing tapes.
Curious about the capstan motor mounting; fairly wide slots, held in place by rubber mounts.
Are the rubber mounts available? I may replace the motor and would want to replace those rubber pieces as well.
stynger007
275
72
28
59
The Great White North Canada
Hello, The back side of the motor has an adjustment attentuator, a number 1 flat jewellers screwdriver can gently punch through the small square sticker . The attentuator is very delicate you`ll find it behind a sticker in the middle. You`ll need to punch the sticker gently , and spray a very small amount of switch and contact cleaner in the hole. Insert the jewellers screwdriver . Gently insert the screwdriver as it`s in play mode , tickle the insides by finding where the screwdriver will drop into the slot. Gently work it until it plays faster, slower, repeat several times. Find the proper speed ( There`s a phone app for that) . Never press in hard, funky things will happen. My thoughts are, the attentuator inside the motor is oxidized and needs cleaning.
Don`t be a stranger- report back with your findings, and post pictures of this and other units you have. The community appreciates giving back. Good luck, looking forward to your next post.
Reactions: Radio raheem
429CV23
17
4
Thanks stynger007, great info!
I ordered and received a replacement capstan motor. When apart, I powered the original motor a few times and it def had a bearing issue. Making plenty of noise. I removed the pulley, then put a couple drops of synthetic machine oil on the shaft. After a few power ups, she is spinning fine without any noise. I decided to roll the dice and keep the original capstan motor in it for now.
What a difference! Initially the W/F was >0.12, tapping 0.5 when it would momentarily drag. After oiling the motor it is now a very respectable 0.06-0.08, and spinning 3001Hz on a 3000Hz cal tape.
One word of caution on adjusting motor speed. Always use a ceramic or plastic shaft screwdriver, or wrap tape around a metal shaft screwdriver to prevent shorts. Ceramic shaft drivers are extremely cheap, like $5 for a set of 3 or 4. Well worth the cost.
Pretty impressive little deck. I may take the time in the near future to run a frequency response test on it with my Nak T-100, see how good the heads & electronics are. Still not too hopeful on that considering the drop in signal quality when going from an 8kHz to 10kHz cal tape, but, still might be worth graphing it.
