national RX-PF9F
1,296
294
Melb AU
Replaced belts works perfect in one direction, having issues with the take up reel in the other direction. The idler tyre is in good condition and works perfectly in one direction only. Has any one worked on or fixed this issue?
It sound amazing with the 3 ohm white drivers.
1,296
294
Melb AU
This is the fault with the idler. The plastic shaft displays wear on the spot were it meshes with the rubber tyre. These two gears are held on by plastic press fit washes.
