MR-X900 (M9998 Japan Edition) Tuner Problem
Phoenix Chan
Hong Kong
I recently received a MR-X900 from Japan. I replaced the belts, cleaned the switches. The tape deck works fine, but when I switch it to "Radio", no sound can be heard from the speakers nor headphone, not even any noise. The same results in both AM and FM. The VU meter shows the signal was not moving at all when I turned the dial.
Please tell me what could be wrong with it. Thank you.
Radio raheem
4,971
922
113
uk
most tuner issues cannot be fixed im afraid unless it is something simple, good luck, maybe someone can shed some light
1,287
287
Melb AU
You may have cleaning fluid on components for the radio. I would wash down the Tuner board with alcohol and a paint brush then place in the sun to dry for a few hours.
