M90 Successful Deck Repair HOW TO
docs
2,558
381
United Kingdom
With Q711 out of board and both wires to solenoid disconnected, I checked at pin 15 which is meant to be low by default, and corroborated against pins 1 (L) and pin 2 (H) to see what each one looked like, pin15 remains low as is base of Q711.
After adding Q711 back into circuit, my oscilloscope is providing different visuals and now pins 1 and 2 and 15 on IC701 look the same which they didn't before.
2,513
346
Interesting about pin 1. Try pulling out one side of R728, and see if there's any improvement. That's connecting pin 15 to a circuit that kills the ff/rew motor when the solenoid engages for recording. You can even see on the schematic how pin 1 ties into it.
2,513
346
If pin 15 looked fine without Q711 and the solenoid, and you reinstalled them at the same time, maybe check Q711 without the solenoid. Pin 15 could go high if D752 on the solenoid board shorted out, and the solenoid's power is allowed to flow backwards through Q711 to pin 15 when the solenoid isn't supposed to be running. Power is always present on the input side of the solenoid and D752, waiting for Q711 to switch on. Power isn't supposed to flow to ground until Q711's base is energized, so if it was allowed to reach the collector without switching on, it might decide to go backwards through the base and over to pin 15 instead. Once the base goes high and connects the collector to the base, now the base sits at a higher voltage than the emitter, which is grounded and connected to the collector now, giving power a much easier path to ground.
RaleighRon
Eldorado, il 62930
Great info in this thread. I need to order belts for my M90. Saw another post debating size also. Really like to get links for where to buy each belt if possible. There's a set on ebay but the guy had like 89 negatives the last few months lol.
If there's a good source in the USA you use links would be greatly appreciated to eliminate me buying the wrong belts. Thanks.
