They WILL sound better and with the foam surrounds you will definitely move more air.
Definitely will have better bass.
Less overall volume output because of the impedance difference.
Will those fit???? probably not.
the magnets will hit the power transformer.
I had to take a grinder to the magnet on mine and take at least a quarter inch off the corner of the magnet to make it fit.
The ones you are looking at look bigger/deeper than the ones i put in.
