I have a bad woofer for this model boombox. Trying to find a Sony replacement, or a suitable sub with proper specs and dimensions. Hole pattern is 105mm corner to corner, depth is around 45mm, edge to edge of frame is 107mm. Model of speaker is Sony 3w 8 ohm part# 1-502-791-11.
Thanks
Eric
Thanks
Eric
