Floyd, this problem exists even if there is a bad bass or treble slider (I can't remember if it's either or both that can causes this issue). The reason is that a break in that slider effectively kills that channel, but if you put the boombox into mix mode (expand or biphonic), then the good remaining channel mixes the signal to the now dead channel, but the mix signal is injected AFTER the slider which is why the channel is restored, but actually it's in mono now since both channels will be playing only the music from one channel.JVC Floyd said:That's what's wrong with mine a bad slider the reason I know is because if I push on it hard enough to balance comes back on but it won't stay on . I was considering bypassing the balance slider all together maybe removing it and just putting the jumper wires but I don't even know if that'll work. I always thought a balance control was stupid anyway all they do is cause problems.
