ICS 5092 , Rexcel JCX 1000
stynger007
275
72
28
59
The Great White North Canada
Bought these in as is condition. The Rexcel had some melted plastic on front from supposedly a spotlight too close, the placards made it , the box inside has 4 separate boards ..2 in the bottom ,one an amplifier board, the other a headphone ,line in out , mic .. both boards suffered liquid damage . The ICS was in better condition, but in need of a full restoration. The Rexcel was used as a donor ..the ICS was non selectable 220v. Swapped out transformer from Rexcel, as well as both decks .the ICS decks were ok but the Rexcel was much less used ..the tuner board in the ICS was staticy and the Rexcel was clear . The speakers in ICS ,one midrange and 2 piezo tweeters were bad. Swapped out from Rexcel.It took 30 hours start to finish and got the ICS going in fine form.. the Rexcel is a back burner unit ,the gent got them from is a well known collector and when the rexcel is restored it will go back to him. Here's a few pics , next reply will show finished ICS.Screenshot_20220814-213540-884.pngScreenshot_20220814-213554~4.pngScreenshot_20220814-213618-052.pngScreenshot_20220814-213540-884.pngScreenshot_20220814-213549~3.png
Reactions: samovar
K dabras
98
DGO. MEX.
That is very nice I have 2 but none of them have cassette belts on/off switch doesn't work and missing 6 screws each but a had I third but most of it was damaged. But I managed to save batteries cover all chromes some of the spare cassette drawers some of the internal parts .. but I wish I can have that radio tuner decal. Do you have an extra one ? Also some of the buttons are broken from the part that keeps them in place in the pin.
