i need belts
10,900
130
Well, for the Rising 20/20 (and clones), I ordered the following belts from Studio Sound Electronics. I can't remember which flat belt it actually needed though. I'm thinking it was the 9.6 but I won't swear to it.
FBS9.0 Flat Belt - Small $0.99
FBS9.6 Flat Belt - Small $0.99
SBO5.0 Square Belt - Other $0.79
monchito
4,602
11
pythonville florida
no sin if you go to there web site you will see a list of the sizes ,,normally what i do i buy 2 of each then as you work on your boxes just write down which ones you have used that way you only buy the ones you are going to need ,, they will not know nothing about the boxes unless you tell them the sizes,, hope that helps you obtw the sony 99 uses a real long one for the deck controls i belive :-) :-) :ninja:
