How to clean this dirty PHILIPS?
ViennaSound
4,713
49
Vienna / Austria
Got today this nice PHILIPS powerplay machine on flea.
So far , so good.
But it must have been in a kitchen for long time...
Full with dirt from cooking. :'-(
How to get off this glueing dirt? :hmmm:
I don´t want to harm the printings on it, so no agressive substance.
I´m afraid i must part the box to get all dirt off.
But what best for a first clean up?
Soap water alone will not work... :-/
monchito
4,602
11
pythonville florida
wow roman you really find some crazy boxes over there :w00t: :w00t: :w00t: :drool: :drool: , the cleaning part i really do not know i belive there was a cleaning solution but the name does not come to mind i belive its something like orange glo or something like that maybe one of the guys might know :yes: :thumbsup: :thumbsup: :w00t:
10,900
130
Ramon is correct. The best thing that I have found to clean grease off a boombox is Orange Glo. I am not sure if Vienna has anything like it though.
http://www.orangeglo.com/c-woodc-500.html
They have an Orange Glo cleaner for kitchen and bath, but I have never used that one. I would imagine it has some sort of micro abrasive in it.
The one you want is for wood floors. Oh, and use sparingly. ;-)
10,900
130
ClaretBadger said:
i'm interested in removing "kitchen baked on grease" also
My Panny 5350 is caked in it!
Same thing Badge, Orange Glo. :yes:
ViennaSound
4,713
49
Vienna / Austria
Did a careful try with a dustcleaner in our company.
Works! :thumbsup:
But anyway i will part the box for a good clean and the belts also need a change.
And i want to respray the speaker grills. :-)
ViennaSound
4,713
49
Vienna / Austria
monchito said:
lets know how it fairs out roman :yes: :yes:
Simply ****! :'-(
Good luck i checked it inside, before i spent all my time on cleaning it.
Radio works, but:
Tapedrive is broken, it must have been dropped bad....
Too much damage inside, not worth to fix that all. :sad:
So stopped restauration, story follows.
But i will store it away, maybe any custom job on it... :blush:
