I fitted new belts to the 8190 after originals turned to goo. After reassembly the deck is not working correctly. Does anyone have pictures showing the belt locations ?
if you post a photo of your mech we can check the setup. There is also mechanical logic in the mech so you may have to turn by hand to reset as the old belts where goo it can get out of sync.
