GF525 What's it Doing?
snedboy
85
Scotland
This is my first boombox and also my first attempt at uploading a video. There's a few things wrong with my 525, on/off button doesn't work, tape decks don't work, bass doesn't work, aerial missing etc. But it also keeps making a noise like a tape reaching the end of the reel and stopping, which is stopping me from enjoying the radio. Also a little metal rod inside tape deck two is constantly spinning. Does anyone know what's going on inside it?
Northerner
5,323
255
North West UK
Deck will be stuck in play due to perished belts I guess. Dodgy sound will likely just need a bit of contact cleaning. If you check for basic servicing instructions in here it's been covered lots over the years :-)
snedboy
85
Scotland
Cheers. I'm not able to get stuck into it yet. Got to get some other stuff done first
