FH 100W
nickstyle
Hi, i just bougt this and i start servicing it as non of the tapes was working and the switches from the amplifier unit had to be cleand.
So i have made the tapes to work and i have start cleaning the switches .
The tape switch from the amplifier unit was the bigest problem and i start pushing it fast when the unit was working.
For some reason the sound stoped ,no signal from the deck tape to the amplifier unit
And for some reason now the REC LED the red one is always on
Anynoe has any ideea where i should look for the problem?
ThaNk you
