Cs90x recording issue
hghareeb
13
Kuwait
Hi,
I noticed a recording quality drop when i do recording for long time, the first 10-20 minutes sounds good after some time if recording the vocal and music sound will start to a kind of vibration or not holding consistency in tone, well I don’t know how to describe it but almost like vibration in tones, I tried to replace the power supply as i have a used spare one with no luck, also i tried to change the belt , I also replaced the motor but with used one so am not certainly sure if it is the motor or not.
Is there any other thing i should start with, something that could be getting hot after sometime of recording?
Regards
hghareeb
13
Kuwait
Pinch roller already replaced with new, then possibly idler ,, forgive my ignorance but where is the idler located, mine has a belt to run and transfer the movement from the motor to the flywheel. Could it be right behind the cassette located?
