Conion spare tape holder
AZA
807
Down Under
Can someone please tell me how to release the tape draw from the boombox to repair it ?
I hope it doesnt involve taking the Conion apart :sadno:
I opened the draw today and then couldnt get it to lock back in place.
When i looked underneath there was a very tiny length of plastic that had
broken off. Im guessing this was the part that locked the draw in.
Im lucky i didnt lose it but now i need to glue it back on.
Any directions would be great thankyou
3,600
14
51
Belmont, Australia
It's a pretty simple affair that will be obvious once you open her up.
It's not to be scare of though!
The back comes off painlessly, just the antennas and power cables to unplug, from memory.
Once you've got the back off it should be plain sailing.
Good luck AZA, you can do it!!
AZA
807
Down Under
Thanks Glue.
I thought maybe it would slot out of place from underneath but if i have to take it apart i guess
thats the go.
Will have a go tomorrow i think. Thanks again
