Conion C100 issue
Katsa
144
5
Houston
Hello,
[SIZE=11.5pt]I'm trying to figure out what could possibly be the issue with my C100. Seems lately that the left speakers always will work but the right sometime cuts out. I can turn it off, then the next time I turn it on the right speakers will work. My guess is it’s a short or loose wire?. Would appreciate any diagnostic tips. Wish there was a good place to take this too nearby but there aint that much in my area.[/SIZE]
[SIZE=11.5pt]Thanks[/SIZE]
[SIZE=11.5pt]Katsa[/SIZE]
-GZ-
2,238
7
Boom Central
Try wiggling you function switch. Probably just need to clean your pots and switches with deoxit. Mine did the same thing.
10,669
168
40
WI
Yup dirty function switch and possibly others. Spray'em and work'em
-GZ-
2,238
7
Boom Central
Sorry, newbie. Translation. Move your function switch back and forth a bunch of times. Turn all your dials back and forth multiple times. This is a temporary cleaning solution to see if dirty switches is the problem.
With your function switch...move it ever so slightly while music is playing...one way or the other without switching the function. You should hear your bad channel come in.
