Just got myself a prime specimen, but apart from the decks needing work I need to de-fog the tuner window. Someone obviously used windex on it at some point and messed it up. What have you guys used to make em crystal clear again?
hi ive always used tooth paste works perfect no sand paper needed I use this on my car headlight lens as well all clear like new againlewdawg said:Just got myself a prime specimen, but apart from the decks needing work I need to de-fog the tuner window. Someone obviously used windex on it at some point and messed it up. What have you guys used to make em crystal clear again?
400 to 1500 is a bit aggressive I would think? Unless your numbering system is different.. I start 1800 and end up on 3000, buff then it comes up like glassCoast Steve said:I used 400 grit, wet/dry paper, then 600, 1000 and finally 1500.
Then buffed with a wheel and polishing compound.
It turned out pretty well but not 100% "flat" looking.
It would be best to use a cork or hard foam block if possible to keep it flat.
Used all the paper wet too. Rinse well between grits.
