Clairtone 7980 lower deck motor voltage
area51
6
Canada
Hi everyone. Nice to talk to you all. just registered here. I'm working on a Clairtone 7980 and the lower deck motor voltage is approx. 15vdc instead of 12. that might be why the first motor basically melted. Anyone had this problem before?
2,515
346
The lower deck's motor can take 8.4-15V. There'a a 33-ohm dropping resistor for it at R343, which, if the motor truly draws 72mA like the datasheet says, will drop it by 2.4V. That means you can't exceed 17.4V without exceeding 15V to the motor. But uh oh, the AC rectifiers on these put out 18-20V!
The reality of it is, R343 is never a 33-ohm resistor; that's only what the schematic says. What they really installed is a pair of zener diodes in series. I don't know what the zener voltage rating is and I haven't measured that spot, but I'm guessing it's very similar on batteries as it is plugged in. If those diodes fail and short out, the motor's going to get more than 15V when using a cord, which might damage it.
Reactions: Hisrudeness
area51
6
Canada
That's great info thanks! I guess im back to the drawing board on the lower deck playing and sounding like the Chipmunks
91
There is an adjustment for motor speed and if it’s not working then the motor should be replaced!!! And FYI the resistor Caution (Eric) is speaking of, tends to need replacement if never done
Radio raheem
4,971
922
113
uk
I have seen this before on other boxes....if there is an adjustable pot on the board linked to the motor, chances are that will need replacing, a real common issue on jumbo boxes
2,515
346
By the way, the original model number for the deck's motor is EG-500AD-2B. However, the EG-530AD-2B will also work
area51
6
Canada
Hi Haven't posted in a while, but working on that same Clairtone again. still sounds like chipmunks even with the motor voltage adjusted to minimum.I get 15.15vdc at the motor and before r343 (2 zener diodes) i get 16 5v. Stumped
