OK. It does sound like your amp module is fine. Which is not necessarily good news. That's because a dead amp is easier to diagnose and find than issues in the preamp. Check the archives. Bredgeo recently had a GF-9595 with similar issues that was tracked down to a defective IC. You might have the same issue -- maybe that is a high failure part. Anyhow. might be worth swapping it to see. Not really the best way to diagnose but lacking appropriate diagnostic tools, parts swapping might be easiest for you. Good luck.
