Hi all,
Looking to purchase some outers, the original S-Woofers are still good.
Original piezo tweeters failed and replaced with 2inch 4ohm Toshiba TV speakers
Should I go with 2 or 4 ohm outer speakers:
Kenwood KFC-E1754 (Whizzer Cone) - they color match the chassis better...
4ohm, 92dB SPL, 35 RMS each,
or
Infinity Kappa 62.9i (Coaxial Tweeters) - they have better sensitivity...
2ohm, 95dB SPL, 75 RMS each
In regards to overall performance, which would perform better ?
(The music played mostly is 80s hip hop, old school, new wave..)
Will the highs be too screaming with the Infinitys?
Is it better to go with the lower RMS Kenwood to match the amp range ?
Will the tiny 7W amp be sufficient to drive the infinitys or is this speaker too hungry for this radio?
On regular listening I would just use moderate volume say 3-4W isn't it to tiny for the Infinitys?
Since the 767 designed to 4ohm speaker, will 2ohm double the output to 14W ?
Any suggestions and thoughts will help here.
or
