Hey Docs, it is the door with the air pump. I've found a tiny hole on the tape door which looks like the spring fits to it but not sure where to attach the other end. I'll post a photo tonight (aus time). I cant work out whether the spring is supposed to attach to the main unit as well as the front case or if it just fixes to the front casingdocs said:If I recall there is a cylinder air pump on this door with a spring that attaches directly to the door. They are prone to breaking and sometimes need reglueing. If you can provide a pic I can show you where it attaches to.
Nice one Dave, I'll check it tonight. Should be a pretty quick fixdocs said:Yes one end fits onto the door onto a little hole and usually needs a bit of glue to hold. The other end goes on the bottom of the air cylinder, I think it attaches to the inner cream part of it.
What a beauty!!alfie said:Thanks again for everybody's input on this one.
Next up is probably going to be my M70.......
All it needs now is stickers for the speakers (fatdog pleeeease)
Hey Brian,Terry said:Hey Alfie, looks good, a hellova lot better than when it lived in my cupboard.
but I gotta ask, what happened to the deck door sticker?
