i restored this a while ago. but i just noticed there is no trebble output on the right channel. it was working fine when i bought it.its only noticable when you turn the trebble right up as you can hear it more on the left side. ive replaced the caps on the volume tone control circuit board on the top right and switch cleaned the contacts.and i removed all the plugs inside and cleaned every contact pin. so i know its not a dirty contact causing it.. but there is still no tone at all to right speaker..does anyone have an idea whats caused this to happen.because i've never come across this problem before
