what he said^^^^^^Transistorized said:Personally, I use my PC to put my mix of songs together then transfer to CD. I then use my component stereo system in the living room to make the transfer. I do this because I can get way better quality recordings. My 3 Head Sony cassette deck allows real time monitoring and has HXPro with tape calibration and bias controls. Also, I am able to EQ the sound if needed. Sometimes I will connect my mp3 player directly to an input on my component system and do the same thing.
I never use any of my boxes for recording because I have really come to enjoy the benefits of the Dolby HXPro headroom extension during playback in my boomboxes. What is really neat is all cassette decks are able to take advantage of HXPro extension whether they have the feature or not. Only Dolby B, C & S require the deck to have Dolby NR for proper playback on those type of recorded tapes. But I like to squeeze every drop of sound out of a cassette that I can....even the cheap ones.
If you are asking with the idea of using a boombox for recordings then use the aux input on your boombox from your PC or MP3 player using a 3.5mm to RCA analog converter cable. If I were to do it on a portable boombox then I would choose my best portable with the highest quality deck (in my case that's the M90) and use the aux inputs to pipe the sound directly into the box for my recordings.
That's great thanksNickeccles said:I use a Technics CD player directly connected to a Technics cassette deck both used solely for making chrome cassette recordings for my boomers! CD's always made on PC & results are stunning tape playback
I agree 100%. My Sony TC-K850es cost way less than my M90 and makes better quality readings.Reli said:
There are only a few boomboxes I would make recordings with.You can find a home hifi deck for less than you would have to pay for a good boombox.
