TRC-931 Static when adjusting volume.
Phil125
8
Anytime I adjust the volume there is a ton of static. Probably a cap. New to boomboxes and there are quite a few caps in there. Can anybody point me in the right direction?
Thanks
Phil
Phil125
8
jimmyjimmy19702010 said:
Spray that volume pot/slider with some switch cleaner/lube.
Next.
Excellent I'll give that a shot. Getting to that pot looks like fun!
Thanks
91
Thanks
You should clean all switches and pots 😉
Bad Boy Bill
Phil125
8
Bad Boy Bill
I'm definitely going to since it takes a bit of work to get to them. I might as well hit them all.
Hajidub
239
64
28
Colorado Springs
It's known in the vintage repair circles that Deoxit brand by Caig is the preferred cleaner for this job. It is a bit of work since you have to remove the tuner, amp, display board to access the knobs/switches. I'd recommend using a paper towel inside the unit to catch any residual. Spray, work the knob/switch a couple dozen times and air dry.
