Sharp WQ-T351 x-bass speaker refoam or replace. Help!
KaneDom
11
Hello guys I was restoring a Sharp WQ-T351, and the hidden x-bass spaker is bad. Probably the foam of it is gone.
As am aware its a small 8cm woofer. Any idea where to find a replacement foam?
EBay is the cheapest route . you have to measure the cone and the frame to get the exact size but most seller give you the specs of the parts they are selling.
6,326
457
You'll need to open it up and see if the speaker is round, oval or square
1,298
292
Melb AU
If there is no sound it maybe the amp circuit and not the speaker. Once you pull it down check the continuity of the voice coil.
What about the twin decks I guess they don't work?
KaneDom
11
Hii sorry for the late response. Both normal and xbass amps are working, as well as the tape decks. The issue is the xbass speaker. The foam surround of it is dead.
