Jump to content
JVC PC-V66 preset memory
  • Please log in to reply
10 replies to this topic
#1 qsky
qsky
  • Members
  • 7 posts
Posted 04 February 2011 - 09:05 PM
Hello all. I have a JVC PC-V66 that will not "remember" the preset stations. Any help would be appreciated. I would imagine it has a battery or cap of some sort for that function, but am not sure where to look. Thanks again in advance.
#2 JVC Floyd
  • Boomus Fidelis
  • 5,164 posts
Posted 04 February 2011 - 09:15 PM
look inside the battery compartment for a slot that hold either a AA or 9 volt battery.
#3 qsky
qsky
  • Members
  • 7 posts
Posted 04 February 2011 - 09:21 PM
Thank you for the fast reply, will look for that first thing tomorrow.
#4 skippy1969
skippy1969
  • Boomus Fidelis
  • 4,428 posts
  • LocationBaraboo Wisconsin
Posted 04 February 2011 - 09:23 PM
I agree with Floyd.
But it might not remember the stations at all when unplugged. :huh:
My PC-X1000 has a memory battery but it only remembers the time on the clock,not the stations. :annoyed: :annoyed:
It erases the radio station memory as soon as it is unplugged from the wall. :thumbsdown: :thumbsdown: :thumbsdown:
#5 qsky
qsky
  • Members
  • 7 posts
Posted 04 February 2011 - 09:29 PM
Thank you also, however it is always plugged in.
#6 MasterBlaster84
MasterBlaster84
  • Boomus Fidelis
  • 5,080 posts
  • LocationNorthern California
Posted 04 February 2011 - 09:42 PM
That's the one thing that annoys me about my X200 and I suspect other similar JVC models are the same way. :annoyed:
Still love these little JVC bass boxes though. :thumbsup:
#7 skippy1969
skippy1969
  • Boomus Fidelis
  • 4,428 posts
Posted 04 February 2011 - 09:45 PM
Yes me too M.B. it is kind of annoying........ :annoyed:
Awesome sounding units though. :thumbsup:
Posted Image
#8 MasterBlaster84
MasterBlaster84
  • Boomus Fidelis
  • 5,080 posts
Posted 04 February 2011 - 09:53 PM
Love the pic Skippy, I hope I come across an X-1000 someday. :thumbsup:
#9 skippy1969
skippy1969
  • Boomus Fidelis
  • 4,428 posts
Posted 04 February 2011 - 09:58 PM
If you do,get it!!! :w00t: :w00t: :w00t: :w00t:
It is an awesome box :stereo:
#10 qsky
qsky
  • Members
  • 7 posts
Posted 05 February 2011 - 03:28 PM
There is no slot in the battery compartment for any batteries other than the ones that can power the unit. I took the back off the unit and searched for anything that looked like a battery and found nothing. When I took it apart I thought I might luck out and find an easily replacable coin type battery, but no luck. Any other tips? Where might I find a schematic for this radio??
Thanks again
Qsky
#11 skippy1969
skippy1969
  • Boomus Fidelis
  • 4,428 posts
Posted 05 February 2011 - 03:31 PM
Thanks again
Qsky
Thats what I thought........ :hmmm: :thumbsdown:
I had a PC V66 once and I'm sure it didn't remember the presets as well. :annoyed:
You might check with 71spud. He has almost every JVC manual know to man,but I know he isn't at home right now.
Hope this helps.
